Old 1st September 2009, 08:55 AM
Beardy_John Beardy_John is offline
Default Gearbox storage/standing
This may sound like a noobish question, but is it ok to stand a Type 9 gearbox on its end on the bellhousing? Want to store it somewhere so it takes up least space.
www.beardyjohn.com Build blog and associated ramblings (Updated - 17/07/09)
Old 1st September 2009, 09:09 AM
I can see no reason as to why not
On some gearboxes the input shaft is slightly proud of the bell housing face, it may pay to stand the gearbox on a couple of thin pieces of wood
This is the way that I have always stored gearboxes
Edit
If the gearbox is going to be stored for any amount of time, put some grease on the input splines & spigot bearing surface.
This will help to protect from rust
Old 2nd September 2009, 09:16 PM
I seem to remember a small vent hole in a round raised part of the lid,the oil may run out of it when inverted,or I could be completely wrong and thinking of something else Ford.
Old 2nd September 2009, 09:25 PM
nope , you,re not wrong
i found out the hard way
Old 3rd September 2009, 08:57 AM
Talking Dry Storage
That'll be why I store gearboxes dry
Besides, I like to drain the oil at an early stage. If it comes out like Hammerite or has lumps of metal
It's not worth the storage space
Old 3rd September 2009, 12:26 PM
I think most of mine came out of the drive shaft end when I tipped it to get it out of the donor, so its probably dry now anyway! Anyone know where this hole is?
Old 3rd September 2009, 05:58 PM
The hole in question is located in the top case of the box,the metal plate that is bolted down.
This should have a raised dome on it and the breather hole is drilled in it and probaly covered by crud,oil will leak from it bet your life on it.
There are no drains on the type 9 as they were filled for life and only have a level plug,it may be a good idea to cover the tailshaft with tape to stop moisture inside the box.
Hope this makes some sense !
