Old 2nd September 2009, 08:53 PM
Default I've been thrown out!
Well after much fun in the workshop local to my factory, I've had to get out and move everything into my garage, due to them no longer having space for 'My Toys'.... cheeky buggers.
So now I'm all squished into my garage at home, forcing my normal car onto the drive. I've had to push the car to the back of the garage to get it to fit in camera frame But I've got my chassis all painted up. seats positioned, all my roll bar mounting points done and the floor panelled. I've just put my engine and gear box back in to mark out brake and fuel routes, to eye up any problem areas.
I'll pop the engine and box back out and start brake lines on the weekend. My wheels are the wrong size / offset at the rear, but its enough to push it around on...... I did however test the driving position, make engine noises as I changed gears and steered, as I believe is the correct thing to do
