Old 10th September 2009, 06:46 PM
Default Oval tube for headlamp mounts wanted/needed
Due to me being thick, I've made the headlamp mounts not long enough, so I'm looking for some oval tubing to make some more. Does anyone have some I could buy from them? Only need about 30cm worth.
Adrian
Old 11th September 2009, 09:30 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, what size tube are you after? I have some i was going to use it came from some stanley built in wardrobes i removed a while back its 32mm a/r 16.2mm a/f but its only 1.2mm wall with paint,
Im planning on making mine with some but havent as yet so cant promise its any good, it does feel quite strong if you try to bend a 2ft length
Ray
Old 11th September 2009, 10:34 AM
Raylee
Sounds good, I may have found some locally, but if it doesn't work out, could I have a bit please?
Adrian
Old 11th September 2009, 03:52 PM
RAYLEE29's Avatar
sure you can. pm me if you want some with your address etc and ill sort you some out
Ray
Old 11th September 2009, 08:13 PM
If you get stuck Metal Supermarkets do it if there is one local to you.
Old 11th September 2009, 08:37 PM
there is a bloke on lcb that sold me some. if you get stuck i will find his name for you.
Old 11th September 2009, 10:58 PM
Thanks chaps, I have some coming from a guy on LCB.
Adrian
