Old 22nd September 2009, 08:43 PM
Default Front Lower Damper Brackets
I received a shiny new set of dampers from Dampertech today, and in the excitement I decided to drive down to the workshop in my lunch hour to try one on the car. But.....The front lower wishbone brackets require reshaping to allow adequate clearance.
Has anyone else had to modify the shock brackets?? I believe I will also have a minor adjustment on the rear uprights.
Old 22nd September 2009, 08:46 PM
dogwood's Avatar
dogwood dogwood is offline
Yes, I had to mod mine to get the proppa clerance
Just looking, see if I got a pic of it
Old 22nd September 2009, 08:48 PM
Cheers David.
Did you adjust the springs or leave them as factory set?
Old 22nd September 2009, 08:52 PM
Hi Nick
Yes, I too had to remove some of the radius on the lower shock mounts to prevent them from making contact with the body of the shock.
I don't think that this will in any way impair the safety of the bracket.
If I were going to make another set of wishbones, i'd probably square notch the corners & then put a small radius on the sharp edges.
After all, that part of the wishbone is not exactly contactable as far as the IVA is concerned
Old 22nd September 2009, 08:57 PM
yup me too, just took a file to them to round them off by a approx 2mm on the corner/edge.
Old 22nd September 2009, 08:59 PM
dogwood's Avatar
Sorry crabby pic again
But as Ronnie said, you have to trim the inner radius down a bit on the bracket.
I'm still fiddling with my shox, but at the moment I've got them set at about 10mm up from their slackest setting. Ie screw collar just touching the spring with no weight on it. Seems to give me a good ride without bottoming out.
The rears I'm having some probs with, got them set hard, and they still bottom out at times..
Old 22nd September 2009, 09:04 PM
Ronnie,
If you got an odd call at 11am today, it was my stupid car that called you! Somehow the bluetooth satnav decided to dial your number when I was programming it whilst rushing to a meeting! - must add i was not driving at the time, promise!
Dogwood
Where did you get the plastic covers from? Is that part of the SVA requirement? I have not seen them for sale anywhere?
Old 22nd September 2009, 09:12 PM
Originally Posted by Spikehaus View Post
Ronnie,
No worries Nick, I was out in the workshop & wouldn't have heard the phone
Don't you just hate it when technology decides it knows what you want to do
Even I don't know that most of the time.
Old 22nd September 2009, 09:22 PM
dogwood's Avatar
Dogwood
Sorry mate, had a little smile at that one. (no offence.. )
The bottom part is a cut down motorbike fork gater. the top is a pushbike inner tube...
HTH...lol
Old 22nd September 2009, 10:40 PM
Question Davids lights
Sorry to hijack this thread
Where did you get your headlamps from David ??
I will be looking to get some largish chrome / polished stainless ones for my build.
