Old 24th September 2009, 08:35 PM
Default speedo cable
working on my speedo cable today, it seems a mighty tight bend in the cable once its attached to the gearbox with the circlip
i know there are angled devices available so that the cable runs straight but these seem very expensive for what they are,
so ..... what have others done?
a thought i had was to run the cable from where it connects onto the gearbox then in to the cockpit area along BR11 & BR4 then up behind the steering column to the instrument pod, would this be acceptable or should i just accept the tight bend within the transmission tunnel route?
your idea,s / advice please.
