Old 26th September 2009, 06:33 PM
Rik178m Rik178m is offline
Default Diff mounts
Could I get away with 4mm instead of 5mm thickness steel?
Can only find 4mm at work
Old 26th September 2009, 06:47 PM
I vaguely remember that Chris mentioned he was thinking of specifying 10mm, instead of 5mm.
Sean
Old 26th September 2009, 06:49 PM
dogwood's Avatar
dogwood dogwood is offline
Not recommended, there is a lot of strain ot these plates.
If compleatly stuck, the at least put a bracket at the back of the diff to help support it.
Old 26th September 2009, 07:00 PM
I'll have to search harder then. Thanks for the quick replies
Old 26th September 2009, 07:11 PM
dogwood's Avatar
I beleive 3ge can supply them ready cut.
If no the look up your local lazer cutting shop.
I wouldn't make them myself again,
cost more than getting them ready cut.
just my opinion
Old 27th September 2009, 06:37 PM
Doesn't cost anything if you can scrounge the steel from the cut offs and make them at work Very tempted to buy the laser cut parts but I'm on a very tight budget!
Old 27th September 2009, 06:40 PM
If you can get the steel go for it. Thicker is OK as well, mine are 6mm (cost me a pint)
As for the cutting out - if where you work has a plasma cutter then you are laughing.
Failing that, I used hole saws in a drill press to start the lightening slots, then joined them up with a jigsaw. Bit of filing and sorted.
Sean
Old 27th September 2009, 07:21 PM
We do indeed have a plasma cutter. Shame we don't have a laser cutter or cnc. The lathe as alot of play in it also which is annoying. Could possibly mill the holes.
Old 27th September 2009, 07:47 PM
The plasma will p**s it. I am assuming you work for a firm that does steel fabrication, in which case you will have better kit that the average DIYer. 5mm plate is nothing to a decent plasma set (40A and above)
If you are any good with the plasma you could do it freehand, or if worried, make a template in MDF (it's only for 2 uses) although you need to work out the size of the plasma tip, then cut parts of the template oversize, and some parts undersize (external is undersize, internal (cutouts etc.) is oversize)
Milling would also work for the holes/cutouts.
My lathe had a bit of play, new leadscrews and nuts in the topslide and cross slide sorted that out
Sean
Old 27th September 2009, 08:05 PM
Kinda yeh, don't really want to mention the names incase I shouldn't be using the bits I am.
The plasma cutter will go through way thicker then 10mm. I'll have some practice and make a template.
Think our lathe needs more then that changing and works too tight!
