Old 28th September 2009, 12:04 AM
spalders spalders is offline
Default welding rear lower wishbones
Hi folks I've just welded up one rear lower wishbone. BUT even though I tacked it and made sure that it was ok in the jig - once I fully welded the narrow end was pulled in 5mm as the weld cooled... Perfectly flat with no twisting in the other axis. I fully welded the bone out of the jig. Has anyone else had a problem with this?
Spalders
