Old 15th October 2009, 02:26 PM
Smile Bush tubes & Camber adjusters
Here you go chaps
As mentioned in another thread. Here is a full set of book spec bush tubes complete with a pair of camber adjusters + the 2 locking nuts.
When I bought my bush tubing I cut the full length up, hence the spare set that I never got round to selling on ebay.
The bush tubes were cut in the bandsaw then machined square & to length in the lathe.
I no longer require the camber adjusters & lock nuts as I have made quick adjusters for the rear of my car
The camber adjusters will require a bit of a wire brushing as they have been made a fair while & were originally only dusted with some satin black as a tempoary coating
The camber adjusters were made using high tensile threadded bar as opposed to general purpose zinc plated studding.
Heres a picy
22 bush tubes, 2 camber adjusters & 2 lock nuts
£25 the lot & including UK Mainland delivery
Hopefully this will do a fellow forum member a good turn
PM me if you are interested
