Old 16th October 2009, 09:14 PM
rapidtornado's Avatar
Question Pinto Engine code!?!?!?
Just bought a 2.0 pinto SOHC engine and the code stamped on the block housing is WJ07823.
I've checked the Ford Engine code ID chart on the Burton Power WWW but there appears to 2 years for this code May 98' and Sept 79'
Is there any other way of identifying? Trying to workout if it's unleaded or not
Matt
Old 16th October 2009, 09:20 PM
it cant be may 98 because they stopped making the pinto well before 1998 the pinto was dropped around 1989-1990 i believe and replaced by the dhoc then cvh then the zetec in 1993-1994
99.9% of iva inspectors will know its a pre 92 engine and the dvla will know from the engine code
Old 16th October 2009, 09:25 PM
Thanks for the quick response Ash, the guy I bought it off said he thought it may have come out of a Capri so I'm guessing the 79' date is the one.
There's seems to be a lot of discussion about the 205 block and the fact it's a good platform for boring out to 2.3 capacity, do you know if this applies to earlier blocks as well?
Old 16th October 2009, 09:28 PM
i,m no engine builder /tuner but with the money you would spend on a pinto engine to produce more power you might as well buy a brand new 2ltr zetec engine , cost approx £650, thats my plan after Iva when my cvh engine "pops"
Old 16th October 2009, 09:33 PM
Big Vern Big Vern is offline
As AshG says pinto production ended well before '98. 1989 for cars and 1992 for transit vans I believe. As for unleaded it's a popular myth that late pinto's were all unleaded. The only pinto's fitted with hardened valve seats were for gas conversions and this was very short lived as valve seats had a tendancy to drop out - a problem that it would seem has not been solved by the aftermarket conversions especially if big valves or high lift cams are used!
HTH BV.
PS even the 205 block is only good to 2.1 unless you go for a stroker crank and a zetec would be much cheaper! some racers do bore to 2.3 but this bore is bigger than the bore needed when sleeving the block and such a block would have a very short life - may be 100hrs at the most....
Old 16th October 2009, 09:34 PM
Good point...
I'm still a newbie to all this kitcar and engine building but got a bargain on fleabay for a 2.0l pinto for £11.50 and just thought I'd overhaul as a little project for the winter. My mate has an Engineering workshop and has done a bit of engine head/block work in the past so just tinkering about really....
Old 16th October 2009, 09:45 PM
frankie boy's Avatar
Hi
The 20liter pinto will throw haynes roadster along very well? even in standerd state
Put a fast road cam and a pair of weber 40 or 45's and well i say no more. Im not sore wot bhp i get but i did get a 4.2 sec 0 to 60 at a local race wot you bring.
my Roadster
Old 16th October 2009, 09:50 PM
gingea1pom's Avatar
Originally Posted by frankie boy View Post
Hi
Jeeeesus, 4.2 sec. I had now idea it would be that quick. That has made me relax slightly about haveing a 20 year old lump under the bonnet.
Build Pictures
Old 16th October 2009, 09:57 PM
Hi Ginge
Just been reading your build diary.... looking good so far!!!
If it weren't for the fact we only had a new baby arrive a week ago I think I would be getting my board marked up as well but probably not the best timing for me at the moment, busy cleanning up sh1te and puke
Good luck with your build and I'll keep checking in progress
Matt
Old 16th October 2009, 10:01 PM
Matt
congratulations on the little one
all the best to your family,
