Old 17th October 2009, 02:59 PM
mopple mopple is offline
Default Donor parts from Estonia
Hi to all, mu first post here, although registered in April.
Currently gathering and refurbishing donor parts for my build. Have already broken a 83 1.6 Pinto Sierra and another 83 2.0 Pinto is waiting to be broken. Also have bought rear axle from a 2.3 diesel with 3.38 ratio diff and disc brakes. Probably will use these for my own build.
So I already have a spare set of donor parts: front uprights with brakes, steering column and wheel, prop shaft, 2 diffs, push in halfshafts, rear bearing carriers with drum brakes and wiring loom.
Know that these parts would be useful for builders in Britain, but the problem is that I live in Estonia. So I had a little idea. As there are still quite a lot Sierras left here. Would it be a viable idea to gather some more donor parts, load them into a minivan, dive to England and distribute them to fellow Roadster builders?
Madis
