Old 19th October 2009, 04:13 PM
DaddyA's Avatar
DaddyA DaddyA is offline
Default Fuel line ends.
Hi,
just wondering how people are securing the fuel hoses to the solid pipes?
Are you using compression fittings or just push on and jubilee clips(or alternative)?
Daz...
Old 19th October 2009, 05:04 PM
car.mad car.mad is offline
personaly i would use jubalee clips, simple and easy but others may do different
Jake
If in doubt... Give it a clout!
My Build Thread - http://www.haynes.co.uk/forums/showthread.php?t=2995
Build Pics http://s804.photobucket.com/albums/yy326/jake_hornsby/
Spent So Far - £90
Old 19th October 2009, 05:36 PM
Daz if you can then sweat on a solder ring copper coupling onto the pipe then the solder ring will give you a bead to seal the tube then a hose clip to hold the tube in place. Worked fine for me.
AndyH
Old 19th October 2009, 06:33 PM
DaddyA's Avatar
Thumbs up
Cheers for the replies,
I was thinking of soldering some olives as a stopper, had to solder on some 90 deg bends as the tube deformed slightly. So thats probably the way ahead.
Planning on using a bike fuel pump so pressure wil be quite low.
Thanks again
Daz...
Old 19th October 2009, 07:26 PM
Originally Posted by DaddyA View Post
Hi,
If you are flaring your own brake pipe ends your tool will more than likely be able to flare your fuel line too.
Thats how i did mine and it worked a treat
Not wanting to teach granny how to suck eggs but when using the clips to secure the flexible hoses to the solid lines make sure you use fuel clips and not ordinary hose clips, the fuel ones tighten up much better on the small diameter stuff.
Old 20th October 2009, 12:28 AM
i flared the ends of mine with my brake pipe tool worked a treat. mark when you say fuel clips do you mean the ones with little screws through them rather than a worm gear jubilee as thats what i have used.
Old 20th October 2009, 08:04 AM
Yeah thats them Ash
If you go in any motor factors and ask for fuel line clips thats what you get rather than jubilee type. Im sure that normal clips would still seal properly but for a few pennies i would rather get the proper ones
Old 20th October 2009, 04:24 PM
Coozer's Avatar
Coozer Coozer is offline
Your IVA inspector will be chuffed with the proper fuel clips as well. When I went for SVA he mentioned they were superb, just the job, better than garden clips.
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
