Old 28th October 2009, 05:07 PM
squbti's Avatar
squbti squbti is offline
Default Exhaust flange CAD drawings
hi guys, i thought i would start on my exhaust this weekend & was wondering if anyone had CAD drawings for the pinto exhaust flange, i would like to have it water cut in stainless . I would be greatfull for any help .
thanks
Samy
Old 28th October 2009, 06:06 PM
Just give the water cutters a gasket, they can do it from that
Sean
Old 28th October 2009, 06:23 PM
squbti's Avatar
would tracing the gasket work ? can i just trace it on a paper & scan it to te computer?
Old 28th October 2009, 06:51 PM
davidimurray's Avatar
I have just been drawing some - haven't made any yet but will get around to it at some point. I've made them to the exhaust port shape + 1.5mm to allow for a tube to be swaged out to fit. You're welcome to a copy of a DXF but I would make a cardboard prototype before you get any cut.
Also if anyone has a drawing for a pinto inlet flange that would be much appreciated - b***dy hard thing to draw!
Old 28th October 2009, 08:55 PM
squbti's Avatar
I´d love a copy david that would be great & i´ll try it first to make sure it fits before cutting the real one .
Old 28th October 2009, 10:56 PM
Right
Just done a quick check against a gasket I have in the house and looks pretty close. Will prob be getting some myself after xmas so let me know how you get on.
So here is the file - as I say use with care!
http://rapidshare.com/files/29929460...lange.DXF.html
Old 29th October 2009, 12:11 AM
david you wouldnt happen to have the inlet one would you?
Old 29th October 2009, 06:49 AM
AnguS AnguS is offline
the guy that does my laser cutting has them on file, both inlet and exhaust for a pinto
pm me and i will put you in touch
Old 29th October 2009, 09:00 AM
i just want the file i don't need them cut
Old 29th October 2009, 06:55 PM
squbti's Avatar
Thank you so much David that looks geat i´ll compare it to the exhaust flange from my sierra & i´ll let you know how it turns out
Samy
