Old 6th November 2009, 09:48 PM
Default Grrr paint
Have spent a jolly couple of hours spraying the chassis in primer.
Then noticed a couple of welds that were still only tacked
Still, better to notice them now, than when the chassis falls apart at 70mph.
So, things I have learned this evening
  • Painting is boring, but a spraygun makes it bearable
  • It's easy to miss a weld with this many joints (not the smokey kind )
  • Overspray gets everywhere
  • Use lots and lots lots and lots lots and lots lots and lots of dustsheets
  • Putting your elbow in the can of primer is not a good idea
  • Did I mention, Painting is boring
Obviously, said paint is now drying, so I have time (and primer) on my hands, hence the overly excessive use of formatting
Anyone else had a fun evening???
Sean
Old 6th November 2009, 10:13 PM
gingea1pom's Avatar
Default Websters cause
Not a fun evening but a very satisfying,
I have just finished a 427 page report complete with two site diagrams, critical path analysis, cross sectional diagrams and mass haul calcs. Finished 4 days early. Happy days.
Build Pictures
Old 6th November 2009, 10:21 PM
i remember the thread i started titled "bl@@dy paint"
and yes i found the odd weld that needed doing too
i can smile about it now tho, thanks Sean
Old 6th November 2009, 10:27 PM
Yes, I remember the fun you had
I'm smiling already, because it will be someone else's turn soon
Hopefully crack on with a 2nd coat tomorrow morning (after sorting those welds) and maybe even the 3rd coat of primer in the evening.
Then it's time for colour (whichever I go for in the end)
Sean
Old 7th November 2009, 09:52 AM
I would rate the painting as the worst part of the build
Did you find that about half way through the painting, the cost of powder coating seemed like a bargain
Where do those missed welds come from !!??
I am sure those pesky Pixies sneak in when I am not looking & nick em
Old 7th November 2009, 10:42 AM
It's certainly shaping up to be, although profiling all the tubes must come close as well
I have thought about PC, but I don't yet have an engine, so need to put the mounts in when I decide what I'm doing. Plus, if I had sent it to the powdercoaters, I would not have noticed the missing welds
I don't know, surely there must be a system for making sure they are all done, it is soo easy to become blind to it once you have just spent a few hours welding up all the joints.
Maybe use little strips of insulating tape on every weld position, then take them off just before the actual weld??
Sean
Old 7th November 2009, 10:46 AM
Life really is too short for some jobs!
Definately getting everything powdercoated, I've done my years of spraying stuff in a single garage (quite a few whole cars!) and covering everything with overspray, no matter how many dustsheets you use, getting high on paint fumes, annoying the neighbours etc.!
The cost of powdercoating really isn't that bad against the material costs for a good paint job, and while everything is out of your garage for a week, you can finish paintig the donor parts and clear the garage up ready for the clean work of assembly.
Adrian
Old 7th November 2009, 12:08 PM
Adrian
well, luckily enough I have a double garage, but it is full of the usual junk (Lawn mowers, mountain bike etc.).
I use a proper mask, so the fumes are no bother. Plus, the paint I am using uses White spirit for a solvent, so not a giddy high inducing as others anyway.
I would have had it powder coated, but the chassis isn't actually finished, still need to do engine & gearbox mounts, oh and headlight mounts.
The donor parts are all done, they were done before I had the steel for the chassis. Everything is cleaned, rebuilt, painted, labelled, and stored in plastic bags or boxes
Anyway, just fired on the second coat of primer. It will get a third coat tomorrow evening, then left for a couple of days to dry off. Then it's colour time
Due to the lingering paint fumes, the garage is gonna be out of bounds today, so am just going to clean my ChAvSTRA, as in REALLY clean it
Sean
