Old 11th November 2009, 10:38 PM
Johnnybizzle Johnnybizzle is offline
Default Reverse Lights Required for SVA?
Hi,
Using bike engine an wiring loom in my roadster, going to put a reverse motor in, Dont want a reverse light, do i have to have 1 seen photos of cars without
Regards Jon
Old 11th November 2009, 10:59 PM
It's IVA now, and yes, you must have a reverse light
Section 29 of IVA manual;
Application: All Vehicles
Method of Inspection: Carry out a visual check of the reverse lamps fitted to the vehicle for operation, colour, number and correct positioning.
Required Standard: Reverse lamps;
  1. They must be operational
  2. The correct number must be fitted to the vehicle (Table 1)
  3. They must emit white light.
  4. They must be positioned to face the rear
  5. They must operate by selection of reverse gear, or be fitted with a telltale warning device.
  6. Where two lamps are fitted they must be fitted symmetrically and be a matched pair.
Sean
car.mad car.mad is offline
a reverse light is NOT part of the MOT test but not sure about the SVA
If in doubt... Give it a clout!
My Build Thread - http://www.haynes.co.uk/forums/showthread.php?t=2995
Build Pics http://s804.photobucket.com/albums/yy326/jake_hornsby/
Spent So Far - £90
