Old 11th November 2009, 11:27 PM
tkpm tkpm is offline
Default Bleed Nipples
I have just started stripping down the front calipers and one of the bleed nipples is buggered.
Does anyone no the size of the nipples
Old 12th November 2009, 08:09 AM
While you're at it, it will be beneficial to change them all whilst off the car. Some may need some heat to undo but don't force and snap them. Put new ones in with a bit of copper slip and will probably save you a lot of swearing later on in the build.
AndyH
Old 12th November 2009, 08:32 AM
Tilly819 Tilly819 is offline
M10x1 replace them with brass ones they they are MUCH less lightly too seize in future
