Old 14th November 2009, 07:40 PM
vincenzo vincenzo is offline
Default Weld spatter
Is there any way of reducing the spatter whilst welding? Not sure how to remove it once it's on there. Advice greatly appreciated!
Vince
Old 14th November 2009, 07:55 PM
Joy's of MIG welding A flapper disc will remove spatter and not too much metal at the same time.
Old 14th November 2009, 08:06 PM
Vince
Hello Vince,
If you fine tune the feed speed, use good quality gas and weld on clean metal it will reduce but you'll always get some splatter. Is Fly says flapper disc soon removes it but don't buy them from B&Q cos they'll rip you off.
AndyH
Old 14th November 2009, 08:16 PM
gingea1pom's Avatar
Andy H
Just because I am lazy where is the cheapest place to buy flapper discs?
I started using one today, ironically to remove splatter and to clean up my weld table it is great. I got mine from Halfrauds.
Cheers Ginge
Build Pictures
Old 14th November 2009, 08:24 PM
onedayTM onedayTM is offline
Hi there,
if you cannot get rid of spatter by altering power or wire speed then you can use anti-spatter spray, just don't drown everthing in it and failing that make yourself a chipper out of old file. grind end like wood chisel and weld metal handle to it. works fine!
tony
Old 14th November 2009, 08:30 PM
Originally Posted by gingea1pom View Post
Andy H
Cheers Ginge
Try These Ginge -
http://www.rightlines.ltd.uk/Zirconium-Flap-Discs.aspx
Cheap as buggary - £1.50 each or e-bay
I just use a local toolstore i have an account with, £2 each. Better than £8 each from B@Q........
Old 14th November 2009, 08:33 PM
gingea1pom's Avatar
Cheers Andy
Build Pictures
Old 14th November 2009, 08:37 PM
Cold chisel and wacking stick, blunt file , anti spatter spray , tip dip , better Co2 argon mix , exspensive 200amp MIG or a TIG. All are options it just depends on wether you want to spend time or money.
Old 15th November 2009, 01:22 AM
quick squirt of wd40 before you weld it does the trick
Old 15th November 2009, 07:51 AM
squbti's Avatar
squbti squbti is offline
welding spray works great & prevents the spater from sticking but also very important to not hold the welder at a great angle, try to keep it almost at 90 deg to the weld & also if you get alot of spater you might be welding a little cold.hope this helps.
samy
