Old 17th November 2009, 10:28 AM
Rik178m Rik178m is offline
Default another pedal box question
how do you work out the height of the main hole for the master cylinder? I'd like to drill it before welding everything.
Old 17th November 2009, 10:34 AM
You offer up your master cylinder, so the input is inline with the hole on the pedal. I moved mine up a few mm as the master cylinder off the Sierra seemed the wrong size for the pedal box?
Old 17th November 2009, 10:42 AM
gotcha. So i have got to weld everything together first. Thanks.
