Old 25th November 2009, 12:26 AM
Default Small machining job for someone
Evening chaps
I have a small amount of machining I need doing.
Yes, I could do it by hand, or on my lathe, but I can't be bothered spending hours cutting and filing and don't want to wreck the lathe.
Plus, I don't have the material to hand.
Basically, I need a rebate milling into 2No. lengths of Aluminium.
Beer tokens waiting. I understand that ally can be pricey, and obviously am more than willing to pay for your time. Can pay you through paypal, pop a cheque/cash in the post, whatever.
I would also need them posting back to me, so factor in a bit for postage
Drawing is attached. PM me if you can do it with an idea of cost.
PS The actual grade stated just seems to be the most common. I have used it for a similar purpose in the past and it was more than adequate. If you happen to have something else to hand that is as strong, then that is acceptable. It will not be treated or anodised (if that makes any difference)
Sean
Old 25th November 2009, 08:04 AM
When do you want these by?
Last edited by Talonmotorsport : 25th November 2009 at 08:06 AM. Reason: being a dumb ass and not reading drawing properly
Old 25th November 2009, 09:54 AM
No major rush.
In the next week or so.
Sean
Old 25th November 2009, 07:46 PM
les g les g is offline
sean
send flakmonkey a u2u on locostbuilders he,s advertising himself for one off small/cheap jobs
cheers les g
Old 26th November 2009, 09:49 AM
Originally Posted by les g View Post
sean
cheers les g
Good point, I think he is on here as well, but he does a lot on LB
Sean
