Old 29th November 2009, 10:56 AM
dogwood's Avatar
dogwood dogwood is offline
Default Ka clock wires?
Morning guys.
Another sunny Sunday morning.......Not!!!
Just bought a Ford Ka clock on the EBlag.
But it came without the plug.
Anyone have a Haynes manual, or happen to know how to wire it up?
It's got a 6 pin socket, I know 2 wires go to the dash light, and one seems to be blank. I could guess the wires,
but frightend of blowing it up and wasting the 99p I paid....
Cheers David
Old 29th November 2009, 11:14 AM
Here that's a nice clock
That'll sit nicely in my dash............Well, that's if I had one
I lost track of Ford wiring mid way through the 90's !!??
See quite a few ka's at the breakers, i'll keep my eyes peeled for a plug
The clock itself will only have a live & netural feed ( Bet you already know that though )
The backlight may have a dimmer circuit built in, this would explain some of the extra pins.
Sorry mate, about as much use as an ash tray on a motorbike
Old 29th November 2009, 11:24 AM
Here you go David
Stolen from a post on the net
Ok looking at the pic which is of the back of the clock
(with case removed) pins are-Top pair of pins (near the clock mech) Left is
Batt + Permanant, Right is-ground, Next pair (down) Left is not used, Right is-
illumination (leds), Bottom pair is Left Igh +, Right is not used, What i've done is join the batt and ign wires together and fed them from a battery
(permanant live) as i only ran a batt pos, ground and panel lights wires into the headlining, I could'nt see the point of an ign supply as the clock needs to be fed all the time, All seems to work ok this way.
Might be of some use
Came from the last post here
Old 29th November 2009, 11:39 AM
dogwood's Avatar
Cheers Ronnie.
I searched high and low last night on the titnterwebby, couldn't find anything.
Here you go 5 mins later, dun and dusted...
Mind you if I blow it up, you'll owe me 99p
or ian619 on the other forum....
Old 29th November 2009, 12:10 PM
Originally Posted by dogwood View Post
Cheers Ronnie.
Know how it feels mate
Recently spent nearly 2 days searching for the pin-outs of my Zetech engines ECU
Gave up in the end
Had a look in the Ford Escort manual..............Yep you guessed it.....There they were
I now have a strict policy of looking in the last place first
Old 29th November 2009, 12:49 PM
dogwood's Avatar
Default Ford Ka, Clock wiring
Hi Ronnie.
It works....
Quick diagram, for anyone else needing it.
Old 29th November 2009, 12:53 PM
Cool
Pleased your sorted mate
I must be off.............There's something on Egay I need to find
