Old 11th December 2009, 01:09 PM
PeteH PeteH is offline
Default B&Q Steel Tube
Hi All.
Before I start welding HandyAndy's chassis together I want to practise.
Has anyone used B&Q steel?
http://www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=9283760&fh_view= detail&fh_location=//catalog01/en_GB/categories%3C{9372015}/categories%3C{9372044}/categories%3C{9372218}/specificationsProductType=sheet_metal___tubing/specificationsSpecificProductType=steel_square_tub e&ts=1260536490200
Thanks
Pete
Old 11th December 2009, 01:19 PM
It would be fine to use for that purpose but its an expensive way to practice
Im sure if you try hard enough you will find some scrap metal from somewhere to play with
Old 11th December 2009, 01:21 PM
crumbs you can get a 6m length for that price.
Old 11th December 2009, 01:36 PM
Hi Pete,
as others have said , that will be fine to practice on but not cheap,
nearly £9 per mtr, wow i need to put my prices up ,
how about finding a local scrap dealer, i,m sure they,ll let you have some scraps of steel for some biscuit jar funds
or some old railings etc from the garden
tho you are correct to practice , tho don,t forget if you do make a mistake you know where i am for a replacement bit,
If anyone with one of my chassis kits needs a replacement part due to a mistake being made, i,m happy to supply a replacement part for the cost of postage.
Old 11th December 2009, 03:50 PM
Enoch Enoch is offline
If you can make your way over to Bracknell I have a box of offcuts of angle that I bought to practice welding with. You are welcome to have an armfull if you want it. PM me if you want it and I will give you collection details.
Enoch (dave)
Old 11th December 2009, 03:56 PM
Enoch (dave)
now thats what i call team work 2 builders with my flat packs working together, thats great to see from my point of view
i,ll go back to cutting some more steel now
Old 11th December 2009, 04:01 PM
How much is a chassis at "£9.00" a meter (thieving,lying robbing, gypsy types.)
Old 11th December 2009, 04:10 PM
approx £378 just for the steel, without me cutting it
Old 11th December 2009, 04:12 PM
Yours is a bargain then !
(Get out more !!!!!!)
Old 11th December 2009, 09:23 PM
you,re right i need to get out more
