Old 16th December 2009, 05:35 PM
Rik178m Rik178m is offline
Default Mig wire
Is 1mm diameter going to be ok? Think the mig unit is 160amps cebora. Borrowing off a mate.
Old 16th December 2009, 05:45 PM
Tatey's Avatar
Tatey Tatey is offline
Chris recommends 0.8mm in the book, I know a couple of members are using 0.6mm wire. I can't see any issue with 1mm wire.
As i understand it the larger the diameter then the larger the current, meaning the hotter the metal will get, meaning you will need to put the welder on a lower setting to prevent yourself from blowing through.
Have a go on some off cuts and see how it goes.
Old 16th December 2009, 05:49 PM
thanks mate
Old 16th December 2009, 06:05 PM
if your new to welding use 0.8mm wire. 0.6mm wire has a tendancy to crumple up if it gets stuck where as 1.8 wont.
Old 16th December 2009, 06:11 PM
Just have a double check of the feed rollers before you buy the wire
My own 180 amp Cebora has only got a .6 - .8 one fitted
Personally I use .6 wire but I do know that many folk disagree with this practice !!??
I expect you are asking because the welder is currently using 1mm wire.
You may find the welds a little bulky using that
Old 16th December 2009, 06:14 PM
tateys rite, the thicker the wire the hotter it gets, its too easyto blow through with 0.6 and 0.8 so 1 will e a challenge, but its dooable
Old 16th December 2009, 08:04 PM
Yeh the bloke I'm borrowing it off has got 1.0mm wire. Will try and get him to sort some 0.8
Old 16th December 2009, 10:16 PM
the weld is as hot as the person welding wants to make it. the only difference that you will notice is that you will have to turn the wire speed up more on 0.6 than you do on 0.8.
thickness of the wire has nothing to do with the power of the welder you wont make a 100amp welder 150amp by putting 1mm wire in it.
what thicker wire allows you to do is add more filler to the weld pool more quickly. a bigger weld pool draws more amps as you are increasing the arc which increases the amp pull on the welder. typically the thicker the material you are welding the more filler you are going to need unless you are doing verious kinds of high friction welding etc.
you dont need to even think about 1mm wire until you hit the 170/180 amp mark which is where you step over to spray transfer which is a whole different ball game where everything gets a lot hotter
Old 16th December 2009, 10:40 PM
I have spent 6 years swearing at my Clarke welder that the insurance replaced a stolen SIP with... The wire feed was always dodgy..
Clarke had supplied it with .6mm wire, .8mm roller set up and .8mm tips I only found out when i replaced the spool... I run .8
it's still not as good as the old SIP.
Old 17th December 2009, 01:32 AM
i have got a little sip 150amp and my backup welder. its a nice little machine. its only ever jamed up once where the jam was so bad i had to replace the liner. duty cycle on it seems pretty good too considering its size
