Old 17th December 2009, 01:37 PM
Default Radiator
I have a clio 2000 model radiator for my roadster the one with a straight spigot and one at 45 degrees
Does it matter which way up it goes?
My guess is that it shouldnt as long as your plumbing is correct but i thought i would ask you all for your opinions on the matter
Hopefully it doesnt matter as it would be much easier for my plumbing if the 45 degree is at the top pointing down
Old 18th December 2009, 10:17 AM
Mark,
just had a look at spuds rad and his has the 45 degree outlet at top pointing down.
Old 18th December 2009, 12:26 PM
Thanks mate, its staying like that then
I assumed this was the wrong way because of a few peoples build pics having the 45 at the bottom not the top, probably doesnt make a difference anyway but thought i would ask, as someone normally knows the answer!
Old 18th December 2009, 12:34 PM
no prob, glad to help.
Old 18th December 2009, 06:49 PM
i put mine at the bottom but either way its a bit of a squeeze
Old 19th December 2009, 08:15 AM
I managed to get my 45 deg at the bottom, but that was with the help of a few 32 mm alloy hose joiners and a hose with a pre formed bend I found on ebay. Took lots of searching but it worked out a treat. Just need my nose cone to confirm its all spot on!
