Old 18th December 2009, 11:31 PM
DaddyA's Avatar
DaddyA DaddyA is offline
Default Coil Pack location?
Hi,
I'm currently cracking on with the wiring and wondered where's the best place to put the coil pack?
Was thinking of putting it on a bracket at the back of the engine - would vibration / heat be a problem?
Or should I stick it just in front of the scuttle near the battery?
Open to suggestions (nice ones obviously)!!
Daz...
Old 19th December 2009, 08:09 AM
Best on the engine if you can find a suitable place. Ford usualy mount them on there.
Keep it away from direct heat like the exhaust.
Old 19th December 2009, 09:52 AM
DaddyA's Avatar
Cheers TT,
Theres a few spare tapped holes on the back of the head, next to where I've put the thermostat housing, it will get hot but not exhaust temp hot.
Always get another if it goes wrong
Daz...
Old 19th December 2009, 10:59 AM
It'll be fine monted at the rear of the head, that is where it is normally located on the Zetech engine, right next to the thermostat housing
If memory serves me right.
The wasted spark type coil pack is located on the engine in all UK spec fords
Old 19th December 2009, 12:33 PM
les g les g is offline
Yep you,re right Ronnie
keeps the length of the leads nice and short
Old 19th December 2009, 01:42 PM
i put mine on the bulkhead. i only did it because i couldnt be bothered to make a bracket to mount it on the pinto
Old 19th December 2009, 03:36 PM
DaddyA's Avatar
Cheers Fella's,
I'd make the bracket today, however, its snowing and a bit on the chilly side.
Time to play in the Quattro
Daz...
