Old 19th December 2009, 07:49 PM
Default VR sensor
Just started on the megajolt wiring today and as per instructions i wired up all the edis components first to make sure it runs before connecting the megajolt
My problem is that i dont know which terminal is positive on the vr sensor(crank position sensor)
Apparently It needs to be correct unles the coil wont fire, the instuctions say look at the remaining wire on the sensor and edis module match up the colours to establish the polarity but my sensor is new and didnt have any wire on it!
I know what each pin on the edis does so anyone know how to establish which terminal is + on the sensor?
Old 19th December 2009, 08:29 PM
Smile VR sensor wires
Right here goes
Sitting here with an uncut EDIS module loom, vr sensor & wiring diagram
The + wire is pin 6 of the EDIS Blue/Green
The - wire is pin 5 of the EDIS Blue/Yellow
Now the difficult part
With the VR wire & plug in my hand, Socket facing away from me & spring clip at the top
The + terminal ( Blue/Green ) is on the right hand side : Pin 6 EDIS
The - terminal ( Blue/Yellow ) is on the left hand side : Pin 5 EDIS
I hope that helps, tis the best information that I have
If you have a generic VR sensor that has the same wire colours simply use a multimeter to identify each wire.
Old 19th December 2009, 08:39 PM
Thats excellent Ronnie
Thats what i love about this forum, ive just spent an hour trawling the internet to answer the same question with no definative answers
Then on here you get the info you need explained in a way that is idiot proof
Thanks again
Old 20th December 2009, 10:38 AM
jiwillia jiwillia is offline
Mark,
This site, "http://www.extraefi.co.uk/drawings.htm" contains usefull data. VR connections are at the bottom of the page.
John
Old 20th December 2009, 11:07 AM
Good info there
Here's a link
Old 20th December 2009, 11:18 AM
Just noticed the Ford EEC-1V wiring diagram there
I won't tell you how long I spent looking for that a while back
Finally found it in the Haynes Escort manual ..... On the bookshelf next to me !!??
Old 20th December 2009, 11:23 AM
if you have any problems realting to ford power plants or the edis..
Then you will find good help on these two sites.
poweredbyford.co.uk
fordpower.org.uk
They are mainly technical sites with non of the crap posts and useless jokes.
Old 20th December 2009, 01:19 PM
this is where i got all my info off.
http://www.autosportlabs.net/Megajolt_Lite_Jr.
edis info..... http://www.autosportlabs.net/Ford_ED...al_information
mjolt car install info..... this one is really good to print and take outside
http://www.autosportlabs.net/MJLJ_V4...allation_guide
ford diagram of edis
