Old 30th December 2009, 10:40 AM
Luke2842's Avatar
Luke2842 Luke2842 is offline
Default Transmission Tunnel Help
Hi all,
I'm sure i'm repeating someone elses question but i've had a look and can't find anything. So I just wondered if there was any harm in using the MT75 transmission tunnel with a Type 9 Gearbox? This is incase i decide to upgrade the gearbox to the MT75 at a later date. I'm planning to build my roadster with a Pinto engine and then upgrade to a 2ltr Zetec on GSXR throttle bodies, has anyone else done a Zetec conversion? If so what gearbox did you use and transmission tunnel?
Thanks, Luke
Old 30th December 2009, 10:51 AM
You need a MT75 sized pedal box to start with though.
The only real disadvantage is you get a little less space. in the footwell.
I will be building with a MT75 tunnel even though I hope to use a Type9 as building a V6 MT75 Box requires a bit of work.
Old 30th December 2009, 05:20 PM
Luke2842's Avatar
Cheers twinturbo thats exactly what i wanted to hear! Just thought bigger would be better, leaves more options open for different gearboxes.
Luke
