Old 31st December 2009, 09:59 PM
martin62 martin62 is offline
Default Steering Column Support
Hi guys I need some help before I crack up just spent the whole day 3 attemps and no joy.My problem is when I cut sw1,sw2,sw3 what way is sw2 suppose to go if you look at pics.Then when I measure across the bottom of sw1 and sw3 I get 478mm and when I measure across tt11 and tr2 I get 458mm also where does the 9 degree angle go I just cant get my head around it.where does cp 24 go, any help would be appreciated
http://s692.photobucket.com/albums/v...nner/?newest=1
Old 31st December 2009, 10:48 PM
Hi Martin
You may find some usefull info in this thread
http://www.haynes.co.uk/forums/showt...eering+support
There was a tutorial on here at some point but I think it was one of the deleted posts
Personally, I made most of the parts up, tacked the frame together then offered them up to the chassis rails in the correct place & angle ..... Then fettled & tweaked to suit.
It all worked out fine ..............The steering wheel & column fits as it should
When you make the angled plates with the slotted holes, then clamp them into position .........The whole frame makes a lot more sense, you'll get a much clearer picture of things
Old 31st December 2009, 11:06 PM
Heres the best picture I have of the steering support frame
I hope it is of some use
Old 1st January 2010, 08:16 PM
Default steering column support
Hi Ronnie thanks for your help got side tracked today hope to get it sorted tomorrow
Old 1st January 2010, 08:38 PM
Hi Martin,
cp 24 go into the junction where BR1 & BR8 & BR2 & BR9 meet, the 2 CP24 plates are there to bridge the gap for the rear most lower wishbone suspension brackets sit.
hope that helps.
Old 1st January 2010, 08:51 PM
Hi Martin,
hope that helps.
Hi Andy thanks for your help will sort it tomorrow
