Old 2nd January 2010, 07:25 PM
dogwood's Avatar
dogwood dogwood is offline
Default 2.0 dif and box??
Question.
Is there any difference between an 1800 pinto diff and gearbox to a 2.0 Pinto
The 1800 ones are tried and tested, so want to know if it's worth sorting out the 2.0 , or just refitting the originals
Cheers David
David.
Old 2nd January 2010, 07:55 PM
David, i might be wrong but i think they,ll be the same as each other, i thought it was just the diesel engined sierra,s that had different ratio,s in the diff & gearbox
on my cvh set up i have the 3.92 diff from an estate car, is there a tag on your diff,s?
Old 2nd January 2010, 08:02 PM
leave the old ones in you know they are good. keep the others as spares. the gearbox ratios will all be the same. the diff could be a different ratio but unless you can work out what it is from the metal tags then i would say dont worry.
Old 2nd January 2010, 08:04 PM
dogwood's Avatar
Don't know, Havn't looked.
Good point about the estate, My 2.0 is an estate.
I'll have a look tomorrow.
David.
Old 2nd January 2010, 08:29 PM
i,ve just received an email from somebody that i don,t know
& in the email is a list of all engine specs to the final drive specs....
David,
your 2.0 efi could have a 3.92 diff or a 3.68 diff
whoever sent that email ...thanks, its good info
Old 2nd January 2010, 08:41 PM
dogwood's Avatar
That was my way of thinking Ash. I'll check the diff's tomorrow anyway,
just out of curiosity
BTW Ash, don't suppose you got a compression tester I could borrow?
David.
Old 3rd January 2010, 02:41 PM
snapper snapper is offline
If you have kept the VIN plate from the donor look at box 10 Axle the code letter in there equates to the fitted axle ratio (although the only real way to tell is to use the diff tag codes or open the diff, the ratio is engraved on the crown wheel)
M=3.14
A=3.36
V=3.38
U=3.62
3=3.64
D=3.92
any diff tag code with AA or AAA is a LSD
There are 3 Type 9 gearbox gear sets for the 4 pot engines, Diesel, P100 and Petrol. The standard Type 9 has a 3.6 to 1 first gear the V6 Type 9 has a 3.3 first gear but has a longer input shaft.
Old 3rd January 2010, 02:49 PM
dogwood's Avatar
Thanks for that Snapper, It'll save me crawling about under the car.
Just put that info into my Fav's. Really usfull bit of info.
David.
Old 3rd January 2010, 03:02 PM
dogwood's Avatar
Snapper, question...
Box 10. is that the 10th letter in the Vin No?
If so then it's an "N"...Which don't show on your list.
Or am I being a numpty.
David.
