Old 9th January 2010, 04:32 PM
Carlo Carlo is offline
Default Sierra rack
Will the standard sierra rack fit with mod's?
Old 9th January 2010, 04:38 PM
dogwood's Avatar
dogwood dogwood is offline
Too long..
David.
Old 9th January 2010, 04:50 PM
happyjo happyjo is offline
Carlo, Try this link for recon MK 2 escort steering rack but you have to give them your old one.
http://www.speedshack.co.uk/Escort%20mk1&2.htm
or
http://www.ekmpowershop9.com/ekmps/s...-rack-44-p.asp
For new fast rack.
Both showing for Escort MK2
Old 9th January 2010, 05:44 PM
GTS?
Rally Designs do them..
or ask your local parts place how much they are, and how much the surchage is. If the rack it £30 and the surcharge is £30 then just don't take in an exchange.
Old 9th January 2010, 07:09 PM
Saturn has just agreed trade prices from Rally Designs so will be putting escort racks, 2.9 and 2.4, on the website soon. Also lots of other Haynes related products. Also no VAT to add to the price as not VAT registered yet - so make the most of it peeps.
AndyH
Old 9th January 2010, 07:25 PM
good news Andy, the site is looking good.
Old 9th January 2010, 07:57 PM
Cheers TT, will be able to start adding for the Single Seater in a while, cant wait for then. The panels are starting to look really good.....
Old 9th January 2010, 08:36 PM
Janne E Janne E is offline
The Sierra will fit if you short it, I´ve done it and it was not so hard.
You may have mod a little in the chassi, look at this pic...
Janne
Old 9th January 2010, 11:36 PM
Yep, all you have to do is cut the rack proper by ~19 cm, drill & tap it for M14x1.5 (or is it 9/16 UNF?), and shorten the shell. Personally, I'm not sure I have the means to do that -- a cheap hand drill will hardly do to drill a 20 mm d12 hole in hard steel What is the right way to drill a hole along the axis in a 50 cm long rod?
Old 10th January 2010, 03:19 AM
Using a milling machine would be the best way and probably the safest.
