Old 16th January 2010, 11:05 AM
aerosam's Avatar
aerosam aerosam is offline
Default How do you plug an unwanted brake line?
Hi Guys,
I'm using my donor's master cylinder, it has 2 outlets, and used to feed to an ABS controller. As I'm not using ABS, and my rear discs are actually bigger tha my fronts (for now) what i want to do is just use one port, and fit a knob type brake balance valve to reduce pressure to the rears. So how do I blank off the other port securely?
BTW, I'm aware the balance vale is a fail on IVA but I'm building this car purely for the track so it's not a problem.
Old 16th January 2010, 11:34 AM
Davey's Avatar
Davey Davey is offline
Why not use one outlet to feed the front brakes unrestricted and the second outlet to the rears via an adjustable restrictor valve.
D.
Old 16th January 2010, 11:45 AM
If it's going to pass the IVA, you need a split system so use both ports.
Old 16th January 2010, 12:00 PM
Davey's Avatar
He did say its purely a track car TT.
D.
Old 16th January 2010, 12:31 PM
aerosam's Avatar
Originally Posted by AdrianH View Post
Use a brake bleed nipple?
Adrian
I like it, simple but effective.
The only other thing I had thought of was putting a hydraulic stop light switch in there.
Thanks!
Old 16th January 2010, 12:45 PM
D.
ahhh....
would still be a good idea to go split anyway!
