Old 18th January 2010, 12:00 PM
semtexsteve semtexsteve is offline
Default diff mouting plates
hi can anyone help which way up do the diff mout plates go ?????
Old 18th January 2010, 12:28 PM
p45 fig 4.18
25mm at bottom 31mm at top.
Old 18th January 2010, 12:49 PM
thank you mate the book dosnt say
Old 18th January 2010, 12:51 PM
From the looks of the pictures you may need some packing washers.
Although I guess it depends where the brackets are mounted, but may allow for having either a 7" or 7.5" diff fitted.
Old 19th January 2010, 02:38 AM
Yep, the size between the brackets is rounded to the nearest cm (180 mm I think), and my diff at least is some 3 mm narrower.
Old 19th January 2010, 08:36 PM
my diff fitted perfectly when it went in the car. i bolted the brackets to the diff then the whole lot to the car. everything lined up perfectly
