Old 26th January 2010, 09:10 AM
dogwood's Avatar
dogwood dogwood is offline
Default Fuel pump, (Lazy question)
Morning guys.
Anyone know the exact location of the fuel pump on a 2.0 efi Sierra.
I'm just being lazy, I haven't even started to look for it yet.
But it's bstd cold outside today, so hoping someone will know.
Save me hunting around for it, freezing me berejeebers off...
I'm hoping I can use the original rather than buying a new one.
Any opinions appreciated
David.
Old 26th January 2010, 10:10 AM
My Haynes manual don't cover the 2 litre EFI sierra
But if it is the same as the 2 litre DOHC it'll be in the tank ............Very much, same as fitted to the Mudaneo & Escort Zetec engined cars
Can't remember if there is an access plate under the rear seat, so as you can lift out the pump & sender assembly !!
Dare say you can soon make one
Old 26th January 2010, 10:46 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Mine was in the tank too j reg dohc estate, but earlier cars had a separate one which you should find near the tank.
turn the ign on and you should hear it near the drivers side rear wheel arch
theyre normally in a separate cradle and have a large inlet and a smallr banjo fitting outlet
hope this helps Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 26th January 2010, 11:14 AM
i wouldn't turn the ignition on he's took the engine out so it will piss fuel 30foot across the garden
it will be in the tank dave. the easy option is to drop the tank out of the car then take it in the warm to play.
Old 26th January 2010, 11:58 AM
What year sierra is it.
Pre 90 Spec has external pump mounted on the spare wheel well.
Post 90 has intank pump
Unless it's a cosworth and they all had external pumps.
Old 26th January 2010, 01:43 PM
dogwood's Avatar
Thank's for the replies guy's.
Glad I didn't spend all morning underneath it looking
Assuming that it's in the tank then ( It's a Jan 1990, TT)
I don't fancy the idea of refitting in the new tank.
Therefore I will need an external one.
Is this the type of thing I need?
http://cgi.ebay.co.uk/Facet-Type-Ele...em5634f 20f9c
Again any advice appreciated
David.
Old 26th January 2010, 01:56 PM
Certainly looks like just the thing you need
The listing does state that it is suitable for injected engines.
I dare say that you'll get some sound advice from someone a bit more familiar with fuel injected engines
Would be a right git, crawling about & freezing your nuts off just to find it's in the tank
Old 26th January 2010, 02:02 PM
If it's feeding a fuel injected engine then it will most likly need about 3bar. That pump only goes to about 9psi so it would not work.
Old 26th January 2010, 02:07 PM
Sierra tanks can be a right pain top get out.
Old 26th January 2010, 03:34 PM
dogwood's Avatar
Thanks for that TT.
When I first see 3bar I thought WT
But having looked on the tinternet It looks like you are right
Not that I ever doubted it
So still looking for a propa job
David.
