Old 29th January 2010, 09:14 PM
Default Stronger Gearbox Mount
Now I've got all my stuff in the chassis and I've been doing some sitting, making engine noises, I've noticed loads of 'bounce' in the gearbox mount. Its just too soft! Is there any way this can be stiffened up? I've looked around for uprated gearbox mounts, but they are £80!
Old 29th January 2010, 10:58 PM
No bouncing with this mount! Plenty of support all round. Cost around 1 hour and some 6 mm plate or the rack!
Old 29th January 2010, 11:16 PM
I've been looking at the problem and am considering making a metal / aluminium cradle bolted onto the gearbox, and then have 2 rubber mounts on the chassis the cradle bolts onto. Much like miniature engine mounts, using 20mm rubber mounts. Inspired by the rally design product. Obviously mine will look considerably rougher...... but who is going to see it?
Old 30th January 2010, 09:40 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
HI you can get a new standard escort one from burton for £20 or a heavy duty one for £45 assuming you are using a type 9 these should fit as they are v simillar to the sierra one one youve removed the big ugly metal bit i had one knocking around in the garage and it even had captive nuts
burton
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 30th January 2010, 09:49 AM
RAYLEE29's Avatar
rally design do the alloy one above for £45 plus vat but its a bit ott inmo
a new standard one should be stiff enough the rubber goes soft especially when it has got oil on it
Ray
1ST ALBUM HERE
2ND ALBUM HERE
Old 30th January 2010, 03:13 PM
Trophy Blue's Avatar
Trophy Blue Trophy Blue is offline
I got mine from Caterham, only £11 (5 years ago though!)
Old 30th January 2010, 03:16 PM
They haven't gone up much
https://www.caterhamparts.co.uk/prod...271252281b3e0b
Old 30th January 2010, 08:37 PM
RAYLEE29's Avatar
Looks good to me
Ray
1ST ALBUM HERE
2ND ALBUM HERE
