Old 30th January 2010, 06:17 PM
Jimmyd Jimmyd is offline
Default Sensor Plug
Bit of a long shot but would anyone happen to have a plug for a CVH crank pick up sensor needing a new home? Is all Ford ones the same?
J
Old 30th January 2010, 06:21 PM
J
3 pin or 2 pin?
is it like the ones at the bottom of the sensors and connectors page here?
http://trigger-wheels.com/store/index1.html
Old 30th January 2010, 06:40 PM
i "might" have one , will check when i go to the Saturn unit tomorrow.
will get back to you.
Old 31st January 2010, 10:31 AM
Thanks Ash, It's the two pin jobbie. Forum never fails!!
J
Originally Posted by AshG View Post
3 pin or 2 pin?
Old 11th February 2010, 05:32 PM
you can buy new conector if its the oblong type with the little spade type pins in i think thay where made by amp connectors orignaly
like this http://www.simtekuk.co.uk/www.simtek...?p=12&cat=1630
