I will be hopefuly be doing a trial fit of my engine in a couple of weeks, the problem i have is, the rubber engine mounts where perished so i need to replace them.
The local ford garage does not keep them and there price to order them made me full over with shock So my question is what can i use instead or can someone tell me where i can get them, there for a 2l pinto. Thanks in advance Terry |
I am using a 4 cyl Bmw engine but these mount look neat and are cheap. |
I will also be using these engine mounts, I also know that HandyAndy will be too., the engine mounts need to be motived to accommodate them though as they are not as big as the old ones.
1.8 Silvertop Zetec (ZX6R Carbs + Megajolt) + Type 9 My Build Blog: http://www.haynes.co.uk/forums/showthread.php?t=2736 - Last Update: 31st October 2020 Total Spent so far: Stopped counting
I will be using the same as well on an 1800 CVH
Sent from my iPad, from who knows where in the world I was building but I am not now! Build Pictures Build Thread |
Thanks guys will go spend some cash on flea bay.
Terry |
The land rover rubbers are the best to go for, they are cheap and give a nice firm support for the engine. The only problem is you shall have to remake the cvh engine brackets to suit.
A lot of people have had trouble with the sierra rubbers being perished so i think it would be wise for all builders to change their rubbers as part of the build. AndyH
Haynes Roadster / Saturn GRP Bodywork. Now available direct through http://www.gillhamonline.co.uk/ or contact me direct on andrew.hugill@ntlworld.com Regards..........AndyH |
I bought mounts from car builder solutions, they do a nice range that aren't expensive so you may find a set to suit you without modifications.
Check out my Build Blog www.samsv8locost.blogspot.com And here's all my build photo's on a picasa web album http://tinyurl.com/5tbtm46 |
| Thread Tools | |
| Display Modes | |
