Old 1st February 2010, 04:33 AM
Default shocks
Just a query regarding shocks,i know certain aspects have been covered before but my question is regarding shock length.
Are the shocks 13" open + 1 inch extension making them 14" or
13" open including the 1" extension?
My interpretation is they are 13" open incl the 1" extension,only ask as have shocks supplied by OBP which are 14" eye to eye they do have the 1" ext, OBP are insistent they are correct and i dont think so.The box unfortunately does not have the part numbers on.
I note that on Saturn cars website they list them as 13".
Old 1st February 2010, 08:43 AM
Hi ozzy1
The shocks should be 13" open & 9" closed
It was found that after road testing the proto-type the Roadster could benefit from a little more ride height.
This was achieved by the addition of 1" extensions on the top of the shock.
This gave 1" of extra ride height whilst still maintiaing the full range of damping action of the shock.
To sumarise....... 13" open length + 1" extension ....... 14" eye to eye overall length.
It looks as if your OBP shocks are fine & to the correct spec
Old 1st February 2010, 09:12 AM
Ronnie is spot on there Oz, shocks should be 13" with a 1" top hat extension and 1.9" id.
AndyH
Old 1st February 2010, 09:32 AM
Cheers guys,was hoping they were correct as got stung on import duty and gst(vat) on top so didnt fancy having to send back to the uk ,then having more sent out.
Old 22nd March 2010, 06:57 PM
Peter-C Peter-C is offline
I've made up the dummy shocks which are 13" between centres, can anyone confirm if this is correct. Looking at the car it would seem to be riding a bit high. Unfortunately my garage floor is a shade uneven so its difficult to measure it.
Peter
Old 22nd March 2010, 08:48 PM
squbti's Avatar
squbti squbti is offline
so if i got 13" i should change them to 14"? is the eye to eye14"?
will 13" eye to eye work?
Old 22nd March 2010, 10:33 PM
You could try them first Squbti, the 1" top hat was added to the original 13" dampers just to increase the ride height. You will probably find that the car is too low.
Kevin at Protech Shocks would add 1" top hats to the dampers for a small fee, assuming they are protech though i'm sure Gaz would do the same.
AndyH
