Old 1st February 2010, 10:37 PM
degmwilliams degmwilliams is offline
Default granada hubs
Does anyone know the diameter of granada front hubs and what is the diameter of the sierra front hubs, iv read on here that if using the granada hubs they need turning down to fit the sierra uprights. The idea is my donor is a granada cosworth so i will be using the bigger brakes on it, but i have sierra uprights and the mushrooms for them.
Is there another way?
Old 1st February 2010, 11:02 PM
Are you wanting to stay 5 stud? or just use the granada barkes on the sierra nuckle?
Old 2nd February 2010, 06:49 AM
Davey's Avatar
Davey Davey is offline
My donor was also a Cosworth Granada but I'm using the Granada uprights and will alter the wishbones design to suit although I don't think there is too much difference (he said hopefully).
D.
Old 2nd February 2010, 08:09 PM
yes id like to use the granada brakes, but would be good if i could be 4 stud.
Old 2nd February 2010, 08:12 PM
To use the granada brakes on sierra knuckles you will need to use Scorpio or mondeo 24V disks and have 11mm of spacing between the knuckle and the caliper mount. You will also need to drill the mounting holes in the knuckle to 12MM.
