Old 5th February 2010, 09:13 PM
Tilly819 Tilly819 is offline
Default Brakes Problems
it would apeer that ash and myself are in a similar boat though i think i have found the problem a wheeping seep around the brake push rod
i have posted a pic of the master cylinder if someone can conferm its origin i think its sierra but having not got a doner car as such i cannot garentee it
i just keep getting air out of the bleed screws after putting litre after litre of oil threw it and there are no leaks at any joints as far as i can tell so i think it must the the seel around the plunger....your thoughts???
chears tilly
Old 5th February 2010, 09:30 PM
That looks the same as mine, which came from a sierra donor that flyerncle & i stripped.
As Spud has mentioned on Ash,s brake thread, he found the seal (closest to the pedal box) between the resevoir & the M/C was weeping, very very slightly, swapped it for the one from my donor solved the problem.
I believe you can get a seal kit to replace all the seals , tho a new M/C can be bought for about £30 if speed is the essence.
Old 5th February 2010, 09:34 PM
Who stripped it ?
See you 2moro
Problem with seal kit is bore may be rusty/scored due to water in fluid through lack of fluid changes
Old 5th February 2010, 09:45 PM
any ideas were i can get a replacement rarther pronto????
tilly
Old 5th February 2010, 09:50 PM
tilly
i,ve just looked on "the bay" & found this one ......item number 150392844314,brand new old stock, £30 buy it now price,
just confirm that it would be suitable for you before ordering.
Old 5th February 2010, 09:54 PM
is the one i have a lucas M/C then???
looked at that one eirlier only just noticed the pic is just a liberary pic
tilly
Old 5th February 2010, 09:58 PM
i,ve just been re checking & found this one aswell, its for a bendix fitting, which looks the same as mine, item number 190368716132
i think this is more likely to be the one you need.
i typed into the search for a "sierra master cylinder " & a few came up.
hope this helps.
Old 5th February 2010, 10:02 PM
chears andy il have to look into those
tilly
Old 5th February 2010, 10:03 PM
Most sierra Calipers are ATE Teves, but that may have no bearing on the master cylinder.
Old 5th February 2010, 10:09 PM
wonder if its worth giving the scrappies a ring in the morning see if they have any sierra in the yard
