Old 9th February 2010, 09:24 PM
Jimmyd Jimmyd is offline
Default CVH Thermostat Housing!!!
Well started my CVH engine for the first time, no exhaust or radiator but in runs!!! So went and got myself a FWD CVH thermostat housing which will fit the back of my head with core plug removed but it's going to foul TR8. Would it be a really bad idea to cut out a section and brace between TR1 & 2. See the green lines in piccy. I'm really not that happy about it but I can't bring the engine forward without having problems with the gear lever etc.
Any ideas.
J
http://i884.photobucket.com/albums/a...r/CIMG2801.jpg
Old 9th February 2010, 09:57 PM
gingea1pom's Avatar
After looking at this on my 1.8 CVH, I think I am going the run a pipe from the original location on the side of the head next to inlet port 4 then use an in line thermostat. Thus keeping the engine in the correct place and not having to cut or modify the chassis.
Cheers Ginge
Build Pictures
Old 9th February 2010, 10:17 PM
That would mean a new manifold with a take off pipe in my case. Never thought of that when I made up the manifold for my bike carbs. I spent to much time thinking about blocking it off!!!
J
Old 9th February 2010, 10:37 PM
gingea1pom's Avatar
Could you not drill out the manifold and attach a pipe?
Build Pictures
Old 10th February 2010, 08:31 AM
gus's Avatar
gus gus is offline
Could you not just fabricate a dog leg in TR8? You would retain the member in one piece but with it just kinking around the thermostat housing.
Gus
