I just ordered one of 'andy's bargain find' fuel tanks, as i'm gonna be runnung an injection engine will i have to put a swirl pot on the bottom of it?
And where abouts have you guy's that have already got one put the vent? |
I have the same question, I ordered one too
I want to use the standard Sierra pump and sender but not sure if that is possible until I have a look at the tank and pump. I think that it may not be possible as the pump needs to pick up from near the bottom of the tank so some creative engineering may be required. Sorting out a return is dead easy, it's just a pipe inlet, if using the standard submersible pump the return is built in to the mounting plate, the same as the outlet pipe. Hope that makes sense.... |
I hadn't decided on the type of pump i was gonna use yet, will probably go for an external one like the escort xr3i used to have
I think the cap is vented, there's a small hole in it.
| Thread Tools | |
| Display Modes | |
