Old 20th February 2010, 03:18 PM
Default Clutch Cable Linkage - Pedal Box End
Help Please................
I have spent the last four hours playing around with the original Sierra XR4x4 clutch cable. I have made a small roller to help gain adequate travel on the clutch pedal, however to gain the 30 mm movement required on the fork arm it is causing the pedal to be in an un-drivable position.
Does anyone have any photos of how they have connected it???
I will upload the photo of what I have done onto flicker - linky below
Old 20th February 2010, 03:49 PM
Would it not be feasable to remake the clutch pedal with a curve on it to give the necessary clearance/travel to put it in a more natural position? just a thought?
Old 20th February 2010, 03:56 PM
Is this a common problem? the 4x4 cable is not different in it's fittings than any other sierra clutch cable.
Old 20th February 2010, 04:25 PM
I have been thinking about remaking the clutch pedal, however was hoping for some info before I end up with 10 different versions!
Old 20th February 2010, 07:38 PM
drury318 drury318 is offline
I just bought an old stock capri cable from ebay, nice and short and with an eyeley already on the pedal end, its also adjustable.
Dennis
Old 20th February 2010, 08:14 PM
DaddyA's Avatar
DaddyA DaddyA is offline
Dennis
Hi Spike,
did the same as well. Seems ok, not tried engaging with engine running yet though?
Daz...
Old 20th February 2010, 08:47 PM
Dennis
Me to Nick
As with Daz, not tried it with the engine running yet.
Quite happy to send it up to you so as you can try before you buy
Old 20th February 2010, 09:09 PM
DaddyA's Avatar
Me to Nick
Nick,
If you want to try it, i'll whip mine off and you can try it - save Bonzo posting.
Daz...
Old 20th February 2010, 09:21 PM
i used a 1.3 capri cable works lovely and is nice and short.
Old 21st February 2010, 08:12 AM
snapper snapper is offline
The difference in some of the clutch cables is the length of the outer cable cover relative to the inner cable, if the outer cover is to short you will have some difficulty getting the action you want.
You can simply add some packing, round tube welded to the pedal box or washers to play with the correct length, to effectivelly extend the outer cover length.
You can do this at the gearbox end but beware of the cable chaffing.
