Old 20th February 2010, 04:28 PM
Default Ally tub bars ( do they have to be removed? )
Do the bars from the ally tub have to be removed if fitting a Glass tub?
Old 20th February 2010, 05:00 PM
gingea1pom's Avatar
TT,
In a word yes!
I was going for a fibreglass rear end from Saturn all along so never fitted the round tubes.
There is a PDF of the modified rear end kicking about on here somewhere.
I was lucky enough to have my fibreglass rear end so could mock up around it. Still not done the top rails though.
Cheers Ginge
Build Pictures
Old 20th February 2010, 05:06 PM
You can leave the tubes on TT but you would have to modify the panel. Best to remove them and fit the supporting arm to the bottom. Easy to cut and as Ginge says the plans are on the forum.
AndyH
Old 20th February 2010, 05:09 PM
Originally Posted by gingea1pom View Post
TT,
In a word yes!
Cheers Ginge
Top rails??
you don,t need any top rails inside the GRP rear tub, just the lower new square tubing, as the tub is self supporting
Old 20th February 2010, 05:24 PM
gingea1pom's Avatar
Andy,
Cheers for that, I was wondering as no one has mentioned it before.
I am down to my last 2m of steal and need that for stand in shocks.
Thanks again
Ginge
Build Pictures
Old 20th February 2010, 05:50 PM
Ginge....
No prob mate
if it did need top rails i would,ve put the info in the thread discussing the rear tub,
basically the tub is secured with the new square tubing as mentioned on the other thread & where the tub meets D11 & SB1 tubes & i think its D9/10 (haven,t got my book at home)
and yes Adrian H is correct,,,,, the "book" dimensioned fuel tank won,t fit with a GRP tub, tho once the tub is trial fitted you can then get measurements to fabricate a tank, or do what i did & bought one that fits
