Old 22nd February 2010, 12:33 PM
Default Fuel pump location
What is the general consensus for the location of the fuel pump? I was going to put in next to the fuel tank, in that unused space behind the wheels. But does a bike carb pump need to be below the outlet? I assume its self priming and therefore it won't matter?
Is there any IVA related into to take into account. I assume as long as the lines are fixed at regular intervals and are in no risk of touching any moving parts, I'm OK? Does the fuel pump need to be fixed on rubber mounts?
Old 22nd February 2010, 12:43 PM
DaddyA's Avatar
DaddyA DaddyA is offline
That's where I'm putting mine, had a similiar post my myself.
Think Ash said his was in the engine bay?? And works fine (Good suction apparently).
Not sure about IVA, suppose as long as your fuel lines are supported sufficiently it should be ok.
Daz...
Old 22nd February 2010, 05:57 PM
dogwood's Avatar
dogwood dogwood is offline
Actualy his is in the rear, just infront of the tank.
Mine is also in the rear in a simlar place
David.
Old 23rd February 2010, 08:58 PM
DaddyA's Avatar
Apologise,
got mixed up with spud69.
Daz...
