Old 22nd February 2010, 06:41 PM
Tilly819 Tilly819 is offline
Talking Iv had a propper test drive
hi all, just thought id let you all now iv been for a test drive today.
OH MY GOD i think we can safly say its rarther quick and VERY TAIL HAPPY
also got it weighed 540kg inc a full tank of fuel so 520kg dry weight tolerance is +/- 20kg on the weigh bridge
good points
fast as anything
very happy to slide
quite predictable
very stable
brakes worked
steering worked
suspension worked
etc etc
set up speado healer (calibrated speado)
dosnt pull left or right under breaking
fronts lock up before rears
bad points
got a puncture
steering wheel needs adjusting slightly to get dead centre on the collum
when i drive at full throttle i get a cough and splutter at about 8k rpm upwards almost like a rev limiter kicking in but it revs fine withough load think it might be the position of the air sensor as it nbo longer in a air box and i have a scoop in the bonnet pulling the air into the inlets.
got really dirty
and after all of that i forgot to properly check self centering, but i dont recall it being a problem so i think it does ok
hopefully IVA will be next week or the week after just waiting for nottingham to call me, vosa have sent all my aplication folder back and seemed happy with it.
gear stick too tight
jobs still to do:
loosen bearings on gear stick
fit difernt rear reflecters (ones on it i dont think will be ok for IVA
set up gear indicator (should have done that today)
sot out air sensor
adjust stearring wheel
pad steering wheel face
general IVA prep, edge trim, etc ball joint covers etc
chears tilly
Old 22nd February 2010, 06:49 PM
Nice one Tilley
Green with envy mate
I hope things go well with your IVA when the day arrives
Old 22nd February 2010, 06:55 PM
wow so envious
can,t wait to do the same thing.
all the best for the test Tilly
oh ....and by the way WELL DONE, to build a car from scratch is a massive achievement
Old 22nd February 2010, 06:59 PM
gingea1pom's Avatar
That makes me jealous as f**k.
I can’t wait until I get to that stage I have a huge army camp to practise on.
I bet you were like a kid in a sweet shop
Good luck on the IVA, remember a nice break-down of events would be good
Cheers Ginge
Build Pictures
Old 22nd February 2010, 07:36 PM
if you have the off centre mushrooms and they are put in right (hole to the front of the car) then it will self centre fine.
mine self centres as good as any tintop i have ever driven. think dave setup the front end with 1.5-2deg toe in and a couple of degrees negative camber. he will tell you more, as all i could see was loads of string and lots of scribbling on a bit of paper. seems to have worked as the car sticks like shit to a blanket.
Old 22nd February 2010, 07:51 PM
dogwood's Avatar
dogwood dogwood is offline
Don't ask me, I just pretended I knew what I was doing.
Impressed Ash though.....
Measurement sounds about right.
Think it was 20mm toe in at about 4mtr.
Using the string and tape method.
And yes Ash is correct, his does self centre brill.
Must have done something right....
David.
Old 23rd February 2010, 12:27 AM
Tilly, pics or it didn't happen!
Old 23rd February 2010, 08:25 AM
Wow its good to see another one so close to the IVA. Some pictures would be nice as well. See how you've approached things and how its all set up. Help out us slow coaches
Old 23rd February 2010, 10:14 AM
Big Vern Big Vern is offline
1.5 to 2 dergrees toe in I think you mean 1.5 to 2 minutes or may be 1.5 to 2 mm I hope. would have thought 1 degree neg camber would get the job done.
More caster the better for self centreing.
BV.
Old 24th February 2010, 09:16 AM
im planning on dropping it into the local garage before IVA to get it all lazer aligned.
tilly
