Old 24th February 2010, 10:09 AM
Ryan Ryan is offline
Default cvh engine mounts
Hello,
Does anyone have any pictures or drawings of the mods needed fro engine mounts on a cvh?
I am pretty sure I read you can not use book spec mounts but I can't seem to find any pictures or anything here.
Cheers,
Ryan.
Sorry guys, I have just found some pics of Ginges sexy looking mounts, Dont suppose you have any drawings or measurments for them do you Ginge??
Old 24th February 2010, 01:03 PM
drury318 drury318 is offline
I made my engine mountings by placing the engine in situ & the making up the mount to bridge the gap if you see what I mean, I originally did this to suit the Ford mountings but when I found out how much they cost to replace if they fail ( about £80 each I think ), I modified them to suit Landrover V8 mountings which are about £3 each. Dennis
Old 24th February 2010, 07:00 PM
DaddyA's Avatar
DaddyA DaddyA is offline
I did the same,
dropped engine in, propped it up and made this for drivers side, you can use the original sierra one for the other side.
Just make sure it doesn't foul the steering column/shaft.
Daz...
Old 24th February 2010, 07:42 PM
I have remade my engine mounts similar to the ones Ginge has made,
Daddy A....... i hope you don,t mind me asking.....but would the way you have made your drivers side mount cause stress onto the rubber mount threaded bolt as its horizontal to the engine?
I thought that by giving it a slight sloping downwards position from the engine would give a stronger mount,
or am I barking up a wrong tree?
Old 24th February 2010, 09:12 PM
Just barking !!!
Goodnight .
Old 25th February 2010, 12:27 PM
gingea1pom's Avatar
Ryan,
Sorry for not getting back to you sooner, we had a ‘bring a boss’ do last night and every thing is still a little fuzzy!!
I made my mounts by getting the engine and gearbox in the correct position then measuring the gap that needed to be bridged.
I am more than happy to take all the measurements you want but I would imagine it would be easier to make them as described.
Let me know what you are after and I will measure this evening, once I have made up with SWMBO!
Cheers Ginge
Build Pictures
Old 25th February 2010, 07:25 PM
DaddyA's Avatar
Andy,
the way I looked at it was, the weight would be directed downwards so putting the weight on the rubber.
If I angled it, surely the weight would be trying to push the mount away????
We'll have to see once its running
hopefully it will be ok, or i'll be making a new mount (hoping thats all i'd have to make).
Daz...
Old 25th February 2010, 07:33 PM
Originally Posted by DaddyA View Post
Andy,
Daz.....
I totally agree with your logic as i too thought the same & had intended to make mine the same as yours,
my question is just based upon , when i looked at the original alloy engine mount from the sierra it has the mounting point at the chassis end lower than the engine end, & so thought i,d try to replicate that positioning ( not easy i know due to the Roadster steering column position).
I,m not questioning the way you have done it, more a case of questioning my own thought process of my mounts.
Old 26th February 2010, 05:51 PM
DaddyA's Avatar
No worries Andy,
i'm sure all roadsters being built will be different and we've all got our ideas.
The amount of different ways I come up with and then think sod it, i'll just make it and see what it turns out like.
Hopefully it wil do the job a treat until an up grade post iva can be sorted.
Daz...
Old 26th February 2010, 08:43 PM
Depending on the rotation of the engine one mounting will be in compresion and the other in tension and to my way of thinking something at 90 degrees to the angle of the stress may tend to bend other than a mounting at a more acute angle like the orignal places the force more vertical.
Hope the above makes some sense !
Looking back at Daz's picture I dont think it will bend.
