Old 28th February 2010, 08:42 PM
Peter-C Peter-C is offline
Default What thread
Can anyone tell me what is the size of the bolts that secure the mushroom inserts in the front hub carriers ? I've lost the originals, so have nothing to compare.
Peter
Old 28th February 2010, 08:52 PM
M12 x 45
Ford Finis code 6077664
Old 28th February 2010, 11:42 PM
Cheers TT
Peter
Old 1st March 2010, 08:28 AM
yep m12
dont get 45mm ones as you have to replace them for longer ones any way as you need the thread to come right through another 15-20mm to bolt the wingstays on
Old 1st March 2010, 08:40 AM
Good Call Ash, I was just going on the ford parts catalouge
Old 1st March 2010, 09:07 AM
people always forget the poor little wingstays
Old 12th May 2010, 05:56 PM
Some time since the initial post but I cannot get M12's to fit. I have some 7/16 bolts and fit fine. Can anyone explain please ?
Peter
Old 12th May 2010, 06:57 PM
davidimurray's Avatar
Originally Posted by AshG View Post
yep m12
Guess who has just cut some new bolts to be nice and flush with the edge of the upright C**k!
Old 12th May 2010, 07:57 PM
Peter
99.9% sure the are a M12 standard metric thread . The threads may be dammaged, clogged with loctite reminants .
Personaly I would run an M12 metric tap through them
A 7/16" UNC bolt would go in there as it is just a tiny bit smaller & of similar thread pitch.
Being M12 metric a 7/162UNC bolt will not provide an adequate grip & will probably strip the thread in the upright when it is torqued up
Welcome to the club mate.
Would you like an entry in my new magazine .... FUBAR Weekly
Old 12th May 2010, 10:55 PM
Cheers Ronnie,
I'll run a tap through tomorrow.
Peter
