Old 15th March 2010, 08:27 AM
Enoch Enoch is offline
Default Steering rack from a Mark 1 Escort
I have been offered a steering rack from a Mark 1 escort. Does anybody know if it will do the job or if it has to be one from a Mark 2 as per the book? I have been told it's only the length of the splined shaft that goes to the steering column that is different but can't find any info to back this up. Anybody know any different?
Thanks in advance.
Old 15th March 2010, 08:51 AM
Not 100% sure .... But I think you'll find that the Mk1 steering rack uses an imperial thread for the track rod ends.
If this is the case .... Might cause you a little hasle when it comes to the steering rack extensions
Sorry, that's the best info I have floating about in that little pea brain of mine
Old 15th March 2010, 08:58 AM
TSM Locost's Avatar
Default MK 1 Racks.
You are correct Ronnie, the Mk1 steering rack uses an imperial thread for the track rod ends.
Be Lucky, Mike.
Old 15th March 2010, 09:43 AM
That's not a big deal as I would have to make extensions anyway so I can put any size thread on them. Anybody know what size thread they are?
Thanks chaps!!
Old 15th March 2010, 10:54 AM
Default Mk1 Rack thread
Although I do not have one here to put my thread gauge on .... I believe the thread may be 1/2" UNF
If you are going to machine your own extensions & have the right tap, tis no real drama ..... You can still thread the outer end with a M14 thread
Old 15th March 2010, 11:28 AM
TSM Locost's Avatar
Checked in Burtons Catalogue 1/2" UNF.
Be Lucky, Mike.
Old 15th March 2010, 11:48 AM
Thanks a lot guys, will have a look through my taps this afternoon and see if I have the right one If I don't it's only a tenner to buy a brand new one so I should still be quids in.
Thanks again,
Dave.
Old 15th March 2010, 11:58 AM
Thanks again,
Dave.
There's a very good chance I have a 1/2" UNF tap if you don't have one .... Happy to give you a lend of it when your ready
I'll have a little look after lunch
EDIT
Would you believe it !!??
I got 1/2" BSF .... 1/2" Whitworth but no 1/2" UNF
Got both sizes of tap, either side of 1/2" UNF though
As they say .... It's the thought that counts
Old 15th March 2010, 04:24 PM
Thanks for looking Ronnie. sod's law strikes again
I will have a look in my stash and buy a new one if I don't have one.
Dave.
