Old 18th March 2010, 02:16 PM
MrFozzieBear MrFozzieBear is offline
Default Diff Centre Height
Hi all,
Could someone tell me the centre height of the prop flange on the diff from the top of chassis rail BR12? i'm fitting the engine and gearbox in but am waiting on my diff bracket so not sure of height,
Thanks.
Old 18th March 2010, 03:04 PM
I,ve just measured mine & its 140mm from the top edge of BR12 to the center of the driveshaft going into the diff, not easy to measure as so much stuff in the way but I measured it using a set square so it should be fairly accurate.
hope that helps
Old 18th March 2010, 03:32 PM
That's excellent, Thank you.
Old 18th March 2010, 04:35 PM
no prob, happy to help.
