Old 21st March 2010, 03:56 PM
DaddyA's Avatar
DaddyA DaddyA is offline
Default Brake pipe.
Just after you thoughts really,
already ran the front brake pipes as per book (to the brackets welded to chassis) before finding out that you cannot have a flexible hose running through the ali side.
I have now moved the mounting points to the ali sides (with reinforcement ring), but now one of the pipes is not long enough.
Do I replace the whole brake line or should I just put an inline joiner in and add the extra I need.
I think I know which way I might go, just wanted ideas.
Daz...
