Old 27th March 2010, 04:34 PM
layotn20 layotn20 is offline
Default adjustable wishbones :( fitting help
iv got some adjustable rear lower wishbones for the toeing in and out, obviously got rose joints on the end. whats the best way to mount them for iva and has any1 got any pictures of some setup?
Old 27th March 2010, 05:06 PM
they the ones from ebay the other day?
Old 27th March 2010, 06:24 PM
nah mate my chassis is the old 3ge chassis wiv inboard suspension, which come with the wishbones.
Old 27th March 2010, 06:34 PM
this is what iv done so far. but not sure if its acceptable as the rose joint whole is bigger than the allthread so might move about in time, ok at the minute.
Old 27th March 2010, 09:19 PM
Try McGill motorsport for the right spacers
Old 27th March 2010, 09:51 PM
the spacers are fine to be honnest. what the problem is that the allthread that goes through the up right is the right size diameter but the rose joint hole is larger so theres play between the allthread and rose joint hole. if that makes sences?
Old 27th March 2010, 09:57 PM
need a bush tube then.
Old 27th March 2010, 10:07 PM
tried same thing happens. the rose joint hole is bigger than the thread so it moves round on the thread heres a pik
Old 27th March 2010, 10:17 PM
just looked on that site are you on about misalignment spacers/reducers?
Old 27th March 2010, 10:35 PM
Different rose joint with a smaller hole????
