Old 27th March 2010, 11:21 PM
geeman's Avatar
geeman geeman is offline
Default Doing bodywork
Ok, well im mock fitting the bodywork now, ive got full Fiberglas set from titron. I was wondering for the side panels, for cutting holes for the front wishbone/steering setup, should i have seen people have cut seperate holes for each thing coming through the chassis, but is there anything bad about just cutting a large section of the side panel off, so i dont have to spend extra time cutting and finishing loads of holes?
my build pics
Old 27th March 2010, 11:26 PM
-Engage frank mode- Well there is no readon not to do it appart from it lookinng crap.. - Disengage frank mode -
-Engage helpfull mode - Put the effort in, it's not worth shortcuttign it, you will end up looking at it and thinking it looks bad, and there's only one person you can point the finger at.. - disengage helpful mode -
Old 27th March 2010, 11:29 PM
geeman's Avatar
thought as much, its just i did the right side panel today, and did each hole separately, only to find i have to make one hole slightly larger as i had cut it slightly off, which p'ed me off a bit, so i thought i could just cut a giant, hole, guess ill do it properly then
my build pics
Old 28th March 2010, 09:12 AM
Just make a good template.
Old 29th March 2010, 12:06 PM
I might be wrong, but I think Roadster No. 1 has huge holes judging by the photos in the book.
Old 7th April 2010, 12:01 PM
geeman's Avatar
ok, im mock fitting the firbreglass rear tub and arches now, should i just cut a big hole out of the rear tub for the wishbones, and how should i mount the rear arches?
my build pics
Old 7th April 2010, 03:22 PM
geeman's Avatar
ok, well ive done the tub now, and will make fittings for the rear arches tomorrow. I fitted the brake/rear lights and indicators as well at the rear, but after all that drilling, i cant touch anything without being in pain. My arms are full of fibre glass bits and it hurts. I was wearing thick gloves as well when i was drilling as i knew fiberglass is a pain to work with. owww!!!
my build pics
Old 8th April 2010, 04:01 PM
geeman's Avatar
ok, i was doing the rear arches and wondered if the gap between the tyres and the arches is meant to be as big as this:
The reason is the arches are already thouching the bottom of the chassis and looking at spuds car in this pic, his gap isnt as big.:
im using 15 in rims and 97.5mm wall tyres...
my build pics
Old 8th April 2010, 04:28 PM
gingea1pom's Avatar
Geeman,
I hate to be a geek but the ‘50’ in 195/50/R15 is a percentage of the 195. The walls of your tyres are 97.5mm tall.
I cant help with the ride height problem though except to say if you put a full tank of fuel in and get two people sat in it will that make a difference?
Cheers Ginge
Build Pictures
Old 8th April 2010, 04:31 PM
geeman's Avatar
Geeman,
amended
Cheers Ginge
hmmm.. should have thought of that.. i guess i'll be fine as the arches wont go any lower on the chassis
my build pics
